How to stop PING
junaid haroon
I have router and one of its interface configured with live IP.I want to stop the PING from internet side ie.that no body can ping my live IP.Where as my internal users can ping websites like google.com etc.
Please help me out how i do this.
14 Replies 14
John Blakley
Easiest way is to put an acl on the interface that you want to block it on:
access-list 100 deny icmp any any echo
access-list 100 permit ip any any
You need the permit any any line afterwards to allow all other traffic through.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi john,
I applied the above ACL on router interface i could not ping the internal interface i have VPN connectivity between two offices.
What i want is this that no one can ping my live IP.My internal users can ping external websites i can also ping the router internal interface through VPN.
*** Edit ***
Actually, I labbed this up and it works fine for me. Can you post your config and a diagram?
HTH,
John
I applied the following ACL as you told me but after applying this Acl still i cannot ping its internal interface via VPN.
ip access-list extended OUTSIDE
permit icmp 192.168.0.0 255.255.255.0 any
permit icmp 192.168.50.0 255.255.255.0 any
permit icmp 192.168.10.0 255.255.255.0 any
permit ip any any
exit
int fa0/0
ip access-group OUTSIDE in
end
in your post you are talking about ping from internet to outisde interface of your router or firewall. In last post you mentioned that you are unable to ping inside host or interface from VPN.
So what is your goal?
Jan
I mean internal interface not external.Look without above acl i can ping its internal interface via vpn after applying acl i cann't.
my goal is very very simple no one can ping my internet interface mean live IP.my users can ping external websites and i my vpn users can ping its internal interface
could you please post whole config of router? Depends on how is your VPN configured.
I tried reproduce your issue and ACL works for inside hosts to internet(traffic permited) and from internet to public Ip and it also works.
Could not simulate your VPN because don't have your config. What IP pool you assign to VPN users?
Jan
Hi john Blakely,
Below is my configurations plz have llok in this and suggest me how implement Acl to stop the ping from outside only.
Current configuration : 3135 bytes
version 12.2
hostname Store_RTR
logging queue-limit 100
enable password *******************
ip subnet-zero
no ip domain lookup
ip name-server 10.16.6.10
ip name-server 10.16.7.12
ip name-server 8.8.8.8
ip dhcp excluded-address 192.168.3.1 192.168.3.10
ip dhcp excluded-address 192.168.3.200 192.168.3.254
ip dhcp pool store
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.254
   dns-server 192.168.0.1 192.168.0.4
   lease 30
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
crypto isakmp key ***************** address 124.109.46.242
crypto ipsec transform-set tset esp-des esp-md5-hmac
crypto map smap 10 ipsec-isakmp
set peer 124.109.46.242
set transform-set tset
match address 101
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
interface ATM0/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0/0
ip address 58.27.221.42 255.255.255.252
ip nat outside
duplex auto
speed auto
crypto map smap
interface BRI0/0
no ip address
shutdown
interface FastEthernet0/1
description inside interface
ip address 192.168.3.254 255.255.255.0
ip access-group INSIDE-IN in
ip nat inside
duplex auto
speed auto
ip nat inside source list 111 interface FastEthernet0/0 overload
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 58.27.221.41
ip access-list extended INSIDE-IN
permit ip 192.168.3.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.3.0 0.0.0.255 192.168.10.0 0.0.0.255
permit ip 192.168.3.0 0.0.0.255 192.168.50.0 0.0.0.255
permit ip 192.168.3.0 0.0.0.255 192.168.90.0 0.0.0.255
permit ip 192.168.3.0 0.0.0.255 192.168.101.0 0.0.0.255
permit ip 192.168.3.0 0.0.0.255 192.168.3.0 0.0.0.255
permit tcp any any eq 67
permit udp any any eq bootps
permit tcp any any eq 68
permit udp any any eq bootpc
permit tcp any any eq 546
permit udp any any eq 546
permit tcp any any eq 547
permit udp any any eq 547
deny   ip any any
access-list 101 permit ip 192.168.3.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.3.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 101 permit ip 192.168.3.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 101 permit ip 192.168.3.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 111 deny   ip 192.168.3.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 111 deny   ip 192.168.3.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 111 deny   ip 192.168.3.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 111 deny   ip 192.168.3.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 111 permit ip 192.168.3.0 0.0.0.255 any
route-map nat permit 10
match ip address 111
call rsvp-sync
mgcp fax t38 ecm
mgcp profile default
dial-peer cor custom
Store_RTR#
John's first ACl is correct.
that will stop pings to the outside interface of your router. but allow pings thru the vpn tunnel.
are you falling into the trap of just pinging from the remote router, which by default will use the outside interface that is not in the vpn. when pinging  from the remote vpn router do ping 192.168.3.254 source vlan1 ( or an ip address that is used in the vpn tunnel)
Richard
Richard's correct. If you just pinging from the router without sourcing the information, the router will use the public side interface. The public interface won't know how to get to your far side lan interface over the tunnel, so if you source it from your internal interface, it should work fine. Otherwise, ping it from a workstation. I don't see anything wrong in the config other than not seeing the acl that I gave you above. There's nothing applied to the wan side interface according to this config.
HTH,
John
Hi john
As i told you before the when i applied the below acl on outside interface i cannot ping its internal interface which is 192.168.3.254 over the vpn.
so i cannot ping my internal interface over vpn thats why i removed that ACL.
permit ip any any
exit
int fa0/0
end
Okay,
Try removing the permit icmp statements. They're not needed. Also, when you're pinging the inside interface, are you doing it from the other side of the tunnel on a different router or a host? Can you ping across to another host on the other side of the router's lan interface?
HTH,
John
ambikamani
Hi Junaid,
Can you plz share the sh ip access-list result for that particular acl.
Ambi.M
John,
I am pinging its internal interface from my head office.its my branch router configuration.There is VPN connctivity between branch and head office.Hopefully now you got it.
