12-30-2013 01:15 PM - edited 03-05-2019 06:51 AM
We have a 3925e router running IOS 15.1(4)M6. One of its current WAN connections is 1000BaseT. We want to migrate it to 1000BaseF. We have the GBIC (GLC-SX-MM) and I know I can just drop it in there.
HOWEVER: I would like to drop it in there whenever I want and have the router continue to use the 1000BaseT interface until I'm ready to switch over. What's the command for "ignore that GBIC and keep using the copper interface"?
Thanks!
Solved! Go to Solution.
12-30-2013 02:40 PM
I think you are looking for the "media-type rj45" command in interface-mode. Later you change to "media-type sfp" when you are ready to switch links.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
12-30-2013 01:25 PM
The default, at least I believe, is g0/0 in software. If you're using g0/1 or 2 now, are you concerned if you connect the fiber module to the router that it will try to pass traffic over that interface instead? If so, you can shut g0/0 and insert your module now and it won't come up until you bring the interface up....I think I'm completely misunderstanding what you're wanting.
HTH,
John
*** Please rate all useful posts ***
12-30-2013 02:40 PM
12-30-2013 03:58 PM
Right you are. I tried that before, but it didn't work--because I didn't have anything plugged into it.
Sorry, it's my first day back from vacation and I'm getting some ID10T errors!
