03-22-2018 11:17 PM - edited 03-05-2019 10:09 AM
How to the upgrade P2P link with existing device Cisco 1905
03-23-2018 01:01 AM
Contact to BSNL and full document requirements. I am not sure which type of connection you have in your office. But I am sure there is nothing to change on your side.
Deepak Kumar
01-06-2024 08:09 AM - edited 01-09-2024 07:28 AM
To upgrade your 2 Mbps bsnl number check code Point-to-Point (P2P) link to 6 Mbps, you'll need to get in touch with BSNL's customer service or technical support. Request an upgrade of your current plan to a higher speed tier, specifically mentioning that you want to increase your link speed from 2 Mbps to 6 Mbps. They will guide you through the process, which might involve plan changes, equipment upgrades, or modifications to your subscription.
