How to upgrade IOS on Router
imediacast2010
anyone have good instruction with the minumum risk to upgrade the router IOS
PRODUCT TYPE (Model Number): Cisco 2801
* SOFTWARE VERSION:IOS Version:12.4(4)XC7
4 Accepted Solutions
Peter Paluch
Hello Ozhan,
This seems to refer to your earlier post about the bus error, doesn't it?
First, make a note of your current IOS feature set (IP Base, Advanced Security, Advanced IP Services, Advanced Enterprise Services, etc.) - looking at the show version and/or on the current image name will help you identify the feature set. Second, find out how much DRAM and FLASH your router is equipped with - again, the show version is your friend here.
Then, try to locate the newest 12.4T or 12.4 IOS using the Feature Navigator at the following link:
http://tools.cisco.com/ITDIT/CFN/Dispatch?act=rlsSelect&task=search&searchby=platform
Select the 2801 as your platform and after clicking on the Continue button, set first the major release to 12.4T, then select the most recent release and then browse over available feature sets to see the hardware requirements and the features available in the particular image. For example, the 12.4(24)T3 image for 2801 in the Advanced IP Services feature set requires 192MB DRAM and 64 MB FLASH. You may also try having a look on the 12.4 track.
You may even try to look for newest versions in the 15.0M track but these IOSes need generally as much as twice the memory than their slightly older 12.4T counterparts so I don't believe the 15.0M would be usable for you right now unless you have a router having lots of DRAM.
After you select your IOS version that would meet the hardware resources you have available, I strongly recommend comparing its available features to your current IOS version using the Feature Navigator again:
http://tools.cisco.com/ITDIT/CFN/Dispatch?act=compare&task=display
If you properly enter the exact information on both your current and your newly selected IOS version into this tool, it will nicely display the different features in both images, as well as the same features.
Best regards,
Peter
Bert Gevers
Hi Ozhan,
for the upgrade procedures themselves, you can use the following page:
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_image.html
HTH,
Bert
Hi Ozhan,
this device has 256Mb of DRAM and 64Mb flash:
<...snip...>
Cisco 2801 (revision 6.0) with 238592K/23552K bytes of memory.
<...snip...>
When performing the upgrade on a 2800, you will have downtime during the time when the device is reloading.
To reduce downtime, you may be able to use the warm upgrade feature described here:
http://www.cisco.com/en/US/docs/ios/fundamentals/configuration/guide/warm_upgrade_ps6441_TSD_Products_Configuration_Guide_Chapter.html
HTH,
Bert
18 Replies 18
Peter Paluch
Hello Ozhan,
Best regards,
Peter
this is the show version result
I am new on cisco router can you check if the ram ok and I am going to follow the link below you send me now
Can I use software to upgrade the IOS and when I do upgrade is it going to be down time?
2801-IMC-LONDON#show version
Cisco IOS Software, 2801 Software (C2801-ADVENTERPRISEK9-M), Version 12.4(4)XC7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 01-Aug-07 00:56 by alnguyen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
2801-IMC-LONDON uptime is 1 day, 6 minutes
System returned to ROM by bus error at PC 0x623A3CF8, address 0x23 at 10:43:44 UK Thu Nov 4 2010
System image file is "flash:c2801-adventerprisek9-mz.124-4.XC7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Processor board ID FCZ1101747H
2 FastEthernet interfaces
4 ISDN Basic Rate interfaces
1 Virtual Private Network (VPN) Module
1 DSP, 16 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Hi Ozhan,
<...snip...>
<...snip...>
HTH,
Bert
Bert Gevers
Hi Ozhan,
HTH,
Bert
Cisco 3800 series routers, Cisco 2800 series routers, and Cisco 1800 series routers support only external compact flash memory cards. Internal flash memory is not supported. For more details, see Using CompactFlash Memory Cards.
How do I know I have compact Flash Memory?
can you check if my memory enough from the log
Do you know if I can find screen shot of the process ?
Hello Ozhan,
As verified above, you have 256MB of DRAM and 64Mb of flash on your device.
In regards to your query about screen-shots, you can find an example of the output expected at the following link prevously provided:
As explained, if you would like to minimize downtime significantly, you can use 'reload warm file url'' instead of just reload.
HTH,
Bert
I have follow the link and I am trying to download IOS but tooks me to software download page
how do I find the correct IOS not sure which one I am looking for
can you help?
Hi Ozhan,
The latest 12.4T version you can find at:
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=12.4.24T4&mdfid=279316777&sftType=IOS+Software&optPlat=&nodecount=6&edesignator=ED&modelName=Cisco+2801+Integrated+Services+Router&treeMdfId=268437899&treeName=Routers&modifmdfid=&imname=...
I would advise to use the same feature set, hence the file to download is:
c2801-adventerprisek9-mz.124-24.T4.bin
HTH,
Bert
I am not able to download any of them ?
  • To download this software you must have a valid Technical Support Services Agreement associated to your Cisco.com user ID.
    • If you do not have a Technical Support Services Agreement you can get one through:
      • Your Cisco Account Team if you have a direct purchase agreement with Cisco
      • Your Cisco Partner or Reseller
    • Once you have the Technical Support Services Agreement you must associate your Technical Support Services Agreement to your Cisco.com user ID with Profile Manager
Hello Ozhan,
you will require a valid Technical Support Services Agreement associated to your Cisco.com user ID.
I would suggest to contact your Cisco account team or partner/reseller to look into the possibilities.
HTH,
Bert
