Community Member
HSRP;HIGHT PRIORITY
HI
IN HSRP MODE;THE ROUTER OR SWITCH IN HIGHT PRIORITY;IT WILL BECOME ACTIVE FOR ALL TRAFFIC.CORRECT
10XS
ALI
Re: HSRP;HIGHT PRIORITY
Hi Ali,
Yes you are right but not for all traffic but for all traffic of that group having high priority. There can be a situation where same router can be a standby router for second HSRP group.
The priority field is used to elect the active router and the standby router for the specific group. In the case of an equal priority, the router with the highest IP address for the respective group is elected as active
HTH, if yes please rate the post.
Ankur
Community Member
HI
ANKUR AVE A LOOK TO THIS:
Router a
interface ethernet 0
ip address 1.1.1.20 255.0 0.0
standby 1 ip 1.1.1.1
standby 1 preempt
standby 1 priority 95
router b
ip address 1.1.1.30 255.0 0.0
standby 1 preempt
this config correct?
10xs
Hi Ali,
You have configured the priority same on both the routers.
Bydefault it is 100 so if you want to keep it same there is no need for "standby 1 priority 95" command.
In this case router with highest ip address will become the active router which is router b in your case.
If you want router A to be active router configure priority as 105
Ankur
And one more thing to add Ankur i think the router which we configure first will become the active router am i correct in this.
Mahmood
hi ali,
just use following in your configuration...
just make two differnet priority
router a
standby 1 priority 100
router b
regards
Devang
Community Member
10xs for all urs reply!
i'll rated all the post
10xs
ALI
106
