04-17-2012 11:16 PM - edited 03-04-2019 04:03 PM
Hi Techies,
I m a Network engineer in company, we have around 800 users in the office.Below is the details of my network infra.
The problem that HSRP is not working working properly, When my active VLAN goes down, Standby VLAN act as a Active VLAN but traffice is fail to
route trought that VLAN and i m not able to ping another vlan from that VALN.
Any early solution is highly appriciated.
Thanks in Advance.
Solved! Go to Solution.
04-26-2012 04:28 AM
Hi Hardik,
First of all I reiterate the idea that it's hard to have an interface vlan use for LAN down. And if they go down it means that your only layer 2 connection is to the firewall.
No, your config will not do anything at all. First of all the "network" statements are wrong on one of the Cores, because you must use the interface's IP when you put the "0.0.0.0" wildcard. But even if they were correct, you are forming a eigrp adjacency on vlan 26 and that's all.WHen the interface vlan 26 will go down your adjacency will go down and that's all.
The main reason for using a dynamic routing protocol is to use a vlan like the one used to interconnect the firewalls (vlan10) to form the eigrp adjacency and to advertise all the connected networks. The expected result - after forming a adjacency on vlan10 - You can use this config :
Core A
router eigrp 26
no auto
net 172.20.10.2 0.0.0.0
redistribute connected
Core B
router eigrp 26
no auto
net 172.20.10.3 0.0.0.0
Dan
04-17-2012 11:24 PM
I suppose that you have
- 2 4506 chassises. Correct me if I'm wrong
- all the vlans on both chassises. Correct me if I'm wrong
The problem could appear if you do not have a vlan configured on one of the chassises or you have it configured but you have layer 2 connectivity issues or also there is no route .
Could you paste from both chassises :
show standby brie
show vlan
Also tell us which are the vlans with discribed issue
Dan
04-22-2012 11:45 PM
Hi DAN,
Thanks for your reply,
Yes you are correct
---- I have 2 4506 chassies
---- I have configured same VLANs on both the switches
---- Not working if VLAN have priority on CORE A switch.
Here below i am pasting some of my vlan configuration and HSRP configuration.
--------ON CORE A------------------------
interface Vlan8
description * 8th Floor *
ip address 172.20.14.2 255.255.254.0
ip pim sparse-dense-mode
standby 8 ip 172.20.14.1
standby 8 priority 110
standby 8 preempt
end
interface Vlan11
description * 11th Floor *
ip address 172.20.19.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip split-horizon
standby 11 ip 172.20.19.1
standby 11 priority 110
standby 11 preempt
end
interface Vlan50
description **** Voice VLAN ****
ip address 172.20.50.2 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
no ip split-horizon
standby 50 ip 172.20.50.1
standby 50 preempt
end
Interface Grp Pri P State Active Standby Virtual IP
Vl8 8 110 P Active local 172.20.14.3 172.20.14.1
Vl11 11 110 P Active local 172.20.19.3 172.20.19.1
Vl50 50 100 P Standby 172.20.50.3 local 172.20.50.1
--------ON CORE B--------------------------------------
interface Vlan8
ip address 172.20.14.3 255.255.254.0
standby 8 preempt
end
interface Vlan11
ip address 172.20.19.3 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip split-horizon
standby 11 preempt
end
interface Vlan50
ip address 172.20.50.3 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
no ip split-horizon
standby 50 priority 110
standby 50 preempt
end
Vl8 8 100 P Standby 172.20.14.2 local 172.20.14.1
Vl11 11 100 P Standby 172.20.19.2 local 172.20.19.1
Vl50 50 110 P Active local 172.20.50.2 172.20.50.1
Default Route towards firewall is configured on both the switches.0.0.0.0 0.0.0.0 172.20.10.6(Firewall IP)
I have also checked uplinks towards my firewall switch and with CDP neighbours command.
I am also attaching small network diagrame for your reference.
As per my knowledge it is routing issue from CORE B, Need your support for above issue
Thanks In Advance.
04-23-2012 03:50 AM
It is a routing issue in Core B.
rgds/bsn
04-23-2012 03:56 AM
Could you tell me your issue is related to :
- local vlans ( intervlan routing )
- traffic from local vlans through the firewall
- both
I can see that currently you have vlan 8 and 11 Active on Core A , and vlan 50 Active on Core B. Do you have this issue with vlan 50 ?
Can you paste from both Cores:
show ip route 0.0.0.0
ping 172.20.10.6
04-24-2012 02:39 AM
My issue is when i shut the active vlan on core A, Core B take the active stat but host on that perticular vlan not able to ping to internet, firewll ip and another vlan configured on core A
Issue is with VLAN that are configured as active on Core switch A
I have attached the word doc. that will clear the doubts u have.
Thanks in Advance
04-24-2012 02:54 AM
Nice output file.
Is the traffic from VLAN26 is ok, when the HSRP Active is CORE-A ?
On what vlan resides 172.20.10.6 ? You should have HSRP on this vlan Between A and B and the firewall should route the internal traffic to the HSRP address.
Please paste the routing table of the firewall. If it's not posible , check the next-hop for 172.20.12.128/25.
Dan
04-24-2012 06:26 AM
Hi DAN,
yes traffic from VLAN 26 is ok when HSRP is active on CORE A. Sorry to say that it is not possible to paste routing table firewall b'coz i dont have access.
Can you make me understand what you are saying about
"On what vlan resides 172.20.10.6 ? You should have HSRP on this vlan Between A and B and the firewall should route the internal traffic to the HSRP address."
"check the next-hop for 172.20.12.128/25."
sorry but i didnt get you on above statements
regards,
hardik
04-24-2012 06:33 AM
another query is why intervlan is not communicating when i shutdown any active interface vlan on core A.......?
example :- if i shutdown interface vlan 26 on core A then core B becomes the active vlan but from core B i am not able to ping firewall ip address and another vlan interface on core A.
04-24-2012 06:51 AM
Could you paste the interface vlan config of the both Cores for the vlan that has the IP 172.20.10.0 .
Dan
04-24-2012 10:39 PM
04-24-2012 11:47 PM
Hi Hardik
Try this
For VLAN 26
1. Remove preempt commands from both Core switches
2. Make VLAN 26 HSRP active on Core B (by making VLAN26 shut on Core A)
3. Unshut VLAN 26 Core A
4. Ensure VLAN26 is UP (not in SHUT state) on Core A
5. Then try to ping FW/internet/other VLAN IP from end machine
Regadrs
Bharat
04-25-2012 12:08 AM
Hi Hardik,
Thank you for the output.
First of all:
"another query is why intervlan is not communicating when i shutdown any active interface vlan on core A.......?"
this is an expected behaviour. Why ? Your core switches are using only a static route toward the Firewall. In a normal functioning both of them have as conncted all the vlans, so they can forward traffic on direcly connected interface.
When you should down a SVI ( interface vlan ) on core A, it will not be able to route the packet back on Core B, because there is only a default route. The simplest solution is to run a dinamyc routing protocol between A and B , let's say EIGRP , and to redistribute connected , this way if any of the cores looses a SVI , it will receive the prefix via the routing protocol.
Core A
router eigrp 1
no auto
Core B
router eigrp 2
no auto
Edited : Regarding the internet problem , it related to the same issue, the HSRP active is Core A , and all the packets from the firewall back to the internal networks, are routed to the Core A, and if you should down the SVI on Core A then it will route back the traffic to the firewall.
My opinion is that the routing protocol solution , will solve your issues.
Dan
04-25-2012 12:50 AM
I edited my last post !
Dan
04-25-2012 01:43 AM
HI Guys,
@ Bharat Negi ----- Thanks for your reply. I tried the same but still it is not happening.
@ Dan ------- Thanks for solution but does that mean I have to run EIGRP for all VLANs ?
Thanks & Regards,
Hardik
