Webcast-Catalyst9k
HSRP over 2 Nexus 5000 switches "Stanby router unknown"
Hey peeps, I'm trying to run HSRP over 2 nexus 5000 switches and I cant seem to get the hsrp switches to see eachother.  Admitedly Im new to nexuses and they have theyere wierd quirks Ive found.  The HSRP config is pretty straightforward but Im , hoping some other eyes see what Im missing....
Nexus 1
Vlan201 - Group 201 (HSRP-V1) (IPv4)
  Local state is Active, priority 100 (Cfged 100), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 100
  Hellotime 3 sec, holdtime 10 sec
  Next hello sent in 1.957000 sec(s)
  Virtual IP address is 172.20.201.254 (Cfged)
  Active router is local
  Standby router is unknown
  Authentication text "cisco"
  Virtual mac address is 0000.0c07.acc9 (Default MAC)
  2 state changes, last state change 00:01:43
  IP redundancy name is hsrp-Vlan201-201 (default)
interface Vlan201
  no shutdown
  ip address 172.20.201.1/24
  hsrp 201
    preempt
    ip 172.20.201.254
Nexus 2
  Local state is Active, priority 110 (Cfged 110), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 110
  Next hello sent in 0.027000 sec(s)
  2 state changes, last state change 00:00:48
interface Vlan201
  no shutdown
  ip address 172.20.201.2/24
  hsrp 201
    preempt
    priority 110
    ip 172.20.201.254
Re:HSRP over 2 Nexus 5000 switches "Stanby router unknown"
Do you have a trunk carrying vlan 102 between both nexus?
Sent from Cisco Technical Support Android App
Yes, trunked over a 2 link port-channel between the two.  Both Vlans exist on each switch.
Re: Re:HSRP over 2 Nexus 5000 switches "Stanby router unknown"
Hello
Can you ping between the svi's - what's the arp table showing
Res
Paul
Please don't forget to rate any posts that have been helpful. Thanks.
371
