09-09-2007 08:39 PM - edited 03-03-2019 06:40 PM
Dear All,
I have configure 2 4503 switch into HSRP mode , they are working alright,I have one confusion that is what will the VTP mode should both the switch work,iI have configured one as server ,and other as client,when i test my hsrp,it works ,but i am not able to see all vlan in standby switch.kindly help.
Amit kulshrestha
Solved! Go to Solution.
09-10-2007 02:46 AM
No u r standby will not work as a server,it will be in client mode.
If these swithes are u r core,then configure them to be as vtp servers one as a primary and other as secondry.
Mahmood
09-09-2007 08:53 PM
I don't think your problem is related to HSRP so the title is a bit misleading.
Let's see the output from the following commands on both switches:
show int trunk
show vtp status
show vtp password
show vlan
09-09-2007 11:25 PM
Friend Edison , your question has solved my problem,I have forgot to give vtp password on standby switch which i have configured as vtp client.now i am able to see all vlan in standby switch.thanxs.But I have 1 more query ,if my active fails ,will my standby switch will work as vtp server or client ,or how it will server my vlan .
thanxs for youe help.
amit
09-10-2007 02:46 AM
Mahmood
09-10-2007 04:42 AM
Amit,
The VTP assignment is not dynamic. If you only have 2 switches, I recommend configuring both as VTP servers.
