Webcast-Catalyst9k
HSRP Problems
Hi misters, I configured a hsrp in a 1800 router, the router funcion perfect, but after 4-5 hours, the data stop to go to the fibre channel, but I still can ping the other line router and the show standby all still show me the active router 1800.
Here is the hsrp conf from the two routers from my location, anyone could se a problem in this conf ?
thanks.
backup router
interface FastEthernet0/0
description Conexao DMZ Actionline
ip address 192.168.202.8 255.255.255.0
speed 100
full-duplex
standby 31 ip 192.168.202.10
standby 31 preempt
standby 31 track FastEthernet0/1 11
interface FastEthernet0/1
description Conexao WAN Fibra Telefonica
ip address 172.16.100.25 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
speed 10
full-duplex
no mop enabled
active router
description CONEXAO COM LAN
ip address 192.168.202.9 255.255.255.0
speed auto
full-duplex
standby 31 priority 110
standby 31 preempt
standby 31 track Serial0/0 11
standby 31 track Serial0/2 11
standby 31 track Serial0/1 11
interface Serial0/0
description CONEXAO COM WAN
bandwidth 2048
ip address 172.16.100.9 255.255.255.252
ip load-sharing per-packet
encapsulation ppp
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
bandwidth 2048
ip address 172.16.100.13 255.255.255.252
encapsulation ppp
interface Serial0/2
bandwidth 2048
ip address 172.16.100.17 255.255.255.252
encapsulation ppp
Re: HSRP Problems
Do you have a network diagram for this one?
Thanks.
Hall of Fame Super Gold
Re: HSRP Problems
Eduardo
I agree that looking at the syntax of your HSRP I do not see a problem. But since we do not know your topology or exactly what you want it to accomplish we can not judge whether there are any issues with it.
I will note that the standby router is tracking the other FastEthernet interface. Tracking an Ethernet interface can be problematic because there are many situations in which you lose the ability to communicate with devices over the Ethernet but the Ethernet does not lose link and therefore does not go protocol down. Until the interface goes protocol down, then track will not detect a problem. I do not know if that is part of your issue or not.
The primary router tracking point to point interfaces with PPP encapsulation would not have this issue.
Also I am not clear about your description of the problem. You say that after several hours that data stops going to the fibre channel. But I can not tell what or where the fibre channel is. Perhaps you can clarify a bit.
Rick
Re: HSRP Problems
I have a site in Campinas and other in Cajamar.
All my applications are in Cajamar.
I have a fibre channel 10 mb and other 3 link with 2 mb.
I use the fibre as the active link but after I started it, above some hours, I can?t open the app from Campinas, but I still can telnet the router in Cajamar.
So if a Change the priority to the router with 3 links, everything works fine and don t stop.
Do you think I must remove the track or not ?
Re: HSRP Problems
Eduardo,
You can change the track configuration, if you use "track 31 interface Fastethernet0/1 line-protocol", so you can change to "track 31 interface Fastethernet0/1 ip routing" or even to "track 31 ip route ip-address/prefix-length reachability".
Best regards,
Rodrigo
184
