12-15-2006 11:34 AM - edited 03-03-2019 03:03 PM
What will be the convergence time if I swap the primary and secondary hsrp switches by changing their priority?
I have switch 1 as the primary and switch 2 as seconday. Now i want switch 1 as secondary and switch 2 as primary..
Thanx
12-15-2006 11:45 AM
If you are changing the priority on switch 2 to make it the active router then it should become the primary right away, probably in <1 second or so. Ofcourse, you should also have the preempt configured on switch 2 for it to become active router immediately based on the higher priority.
Sundar
12-15-2006 10:31 PM
I agree with sunder, it will behave the primary s/w went down. and then sec will come up as a primary. its also depends how much time we have configured as preempt.
pls go through with this url, hope it will clarify.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_white_paper09186a00800a9829.shtml
Regards...Mukesh
