06-25-2012 05:00 AM - edited 03-04-2019 04:46 PM
Hi, I'm trying to setup HSRP on two C877 routers. Fo some reason advertisements / helo packets are not going from one router to the other. I have Cisco switch (C2960) in between and I was wondering If I need to set up something on this switch?
My configuration:
R1:
interface Vlan1
ip address 192.168.10.254 255.255.255.0
ip access-group V1-IN in
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
standby delay minimum 10 reload 120
standby version 2
standby 1 ip 192.168.10.250
standby 1 timers 5 15
standby 1 priority 10
standby 1 preempt delay minimum 5 reload 30 sync 10
standby 1 name GROUP1
standby 1 track ATM0
R2:
interface Vlan1
ip address 192.168.10.253 255.255.255.0
ip nat inside
ip virtual-reassembly in
standby version 2
standby 1 priority 5
standby 1 track 1 decrement 10
Switch:
interface Vlan1
ip address 192.168.10.234 255.255.255.0
no ip route-cache
Debug: (debug standby pack all)
R1:
Jun 25 11:57:14.589: HSRP: Vl1 Grp 1 Hello out 192.168.10.254 Active pri 10 vIP 192.168.10.250
Jun 25 11:57:19.330: HSRP: Vl1 Grp 1 Hello out 192.168.10.254 Active pri 10 vIP 192.168.10.250
Jun 25 11:57:24.079: HSRP: Vl1 Grp 1 Hello out 192.168.10.254 Active pri 10 vIP 192.168.10.250
Jun 25 11:57:28.407: HSRP: Vl1 Grp 1 Hello out 192.168.10.254 Active pri 10 vIP 192.168.10.250
Jun 25 11:57:33.176: HSRP: Vl1 Grp 1 Hello out 192.168.10.254 Active pri 10 vIP 192.168.10.250
Jun 25 11:57:37.336: HSRP: Vl1 Grp 1 Hello out 192.168.10.254 Active pri 10 vIP 192.168.10.250
R2:
Jun 25 11:58:11.536: HSRP: Vl1 Grp 1 Hello out 192.168.10.253 Active pri 5 vIP 192.168.10.250
Jun 25 11:58:15.893: HSRP: Vl1 Grp 1 Hello out 192.168.10.253 Active pri 5 vIP 192.168.10.250
Jun 25 11:58:20.602: HSRP: Vl1 Grp 1 Hello out 192.168.10.253 Active pri 5 vIP 192.168.10.250
Jun 25 11:58:25.230: HSRP: Vl1 Grp 1 Hello out 192.168.10.253 Active pri 5 vIP 192.168.10.250
I can communicate between both routers (using ping or ssh) and CDP is showing neighbours correctly.
Any idea why it's not working correctly?
Solved! Go to Solution.
06-25-2012 05:10 AM
You have access-lists on your VLANs. Are you allowing the HSRP-Packets there? HSRPv2 uses the destination-address 224.0.0.102 (instead of 224.0.0.2 which was used by HSRPv1) with port 1985.
06-25-2012 05:07 AM
Hello Pawel,
in order to have the two routers to exchange HSRP hello packets the switch has to work at OSI layer2 not OSI layer3 as a router for vlan1.
Try after having shutdown SVI vlan1 on the LAN switch C2960, in this way the C2960 will act as an OSI L2 switch.
Edit:
Karsten is on spot here look at the ACL applied inbound
Hope to help
Giuseppe
06-25-2012 05:10 AM
06-25-2012 05:22 AM
ACL was blocking it. Manage to solve this problem. Thanks guys for your help.
