HSRP with Load sharing and redundancy
Hi All Manish this side,
I just want to know that can we achive load sharing and redundancy both, while using HSRP.
Re: HSRP with Load sharing and redundancy
Hey Manish,
Yes you can achieve both using HSRP. To achieve load balancing you have to configure MHSRP.
http://www.cisco.com/warp/public/619/7.html
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ics/cs009.htm
Ankur
*Pls rate all helpfull post
Thanks Ankur,
One more thing can we use ip address instead of preempt in this command "standby 1 preempt".
and which series of routers that we can configure it.
Hi Manish,
You have to have to configure standby ip address and it is the whole purpose of HSRP which gives a virtual ip address. So once ip address is configured then you have to configure "preempt" keyword basically reinitiates election process.
So you have to configure something like this
standby 1 ip
standby 1 preempt
Check the configuartion section
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ics/cs009.htm#wp3330
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12120ea2/3550scg/swhsrp.htm
Ankur
Hi Ankur,
Thanks for helping get this idea, although had learnt about this, but never got this idea to implement the same.
Hey Sam,
You are always welcome and thanks for appreciating my effort.
Ankur
334
