HSRP
Can we use both HSRP and primary link at the same instance for load sharing...
Re: HSRP
Didnt get exactly what you are looking for. You generally configure HSRP on your LAN side for the High avaialbility. You donot configure the HSRP on the serial/WAN interfaces.
If more questions, Pls. revert.
regards,
-amit singh
Silver
Re: HSRP
If you meant load balancing between both routers, than HSRP cannot do that. Only one active router is allowed in HSRP. You can try GLBP:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t15/ft_glbp.htm
But if you have 4 VLANs for example, you can make one router active for 2 VLANs and the other router active for the other 2 VLANs.
Re: HSRP
you can achieve load balancing as well as high availability with HSRP but you shd run two process on bothe the routers making one standy of the other & vice versa
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094e90.shtml
check this for detail info
regards
Haris
128
