HSRP
Below are the HSRP config for my primary & standby router , problem what i am facing is when i connect the secondary router to LAN my lan not able to access remote sites , do u see any abnormalities in my HSRP config for both the routers.
Router name : PBRU2241 ( Secondary )
interface Ethernet0
description --- Customer LAN - MCS with pbru1748 (PRI)
ip address 10.71.7.242 255.255.255.0
ip helper-address 10.72.253.80
ip tcp adjust-mss 1300
no cdp enable
standby 5 ip 10.71.7.240
standby 5 preempt
hold-queue 100 out
Router name : PBRU1748 ( Primary )
interface FastEthernet0/0
description --- Customer LAN - MCS with pbru2241 (SEC)
ip address 10.19.214.250 255.255.255.0 secondary
ip address 10.71.7.241 255.255.255.0
service-policy input COS-IN
speed 10
full-duplex
standby 5 priority 120
standby 5 preempt
standby 5 track Serial0/0.1 20
end
1 REPLY
Hall of Fame Super Silver
Re: HSRP
Anurag
I notice that the primary router has a secondary address configured but the secondary router does not. Generally all routers on a LAN should have the same primary subnet and should agree on the presence of any secondary subnets. Certainly any device on the 10.19.214.0 subnet will not have connectivity if the secondary router becomes the HSRP active router.
You do not show it, but I wonder if there might be an issue with the contents of the routing table on the secondary router as compared to the routing table on the primary.
Rick
85
