You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
HSSI (DB-60) to X.21 cable. Is it possible?
Need to connect a Cisco router to a high-speed modem (8Mbps link). According to the customer, the modem has a X.21 female port. The Cisco is equipped with an HSSI card (PA-2H), DB-60 connector.
Is that possible? I am searching for the appropriate cable (DB-60 to X.21 male), but no luck so far. Looks like there is no such thing.
  • WAN Routing and Switching
1 REPLY
Bronze
Re: HSSI (DB-60) to X.21 cable. Is it possible?
Hi, it looks like the choice of cables for the 2H is limited to a CAB-HSI1 or a CAB-HNUL.
See info in this link.
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_module_installation_guide_chapter09186a008062f011.html#wp1029998
Hope this helps.
488
