HUP AND SPOOK
alsayed
HI All!
i need link that describe the topology HUP AND SPOOK VERY BRIEFLY.this link sould contain design;implementation configuration.
i appreciated ur reply
Ali
scottmac
Level 10
Level 10
Think of an old wagon wheel, or a bycycle wheel - theres a central element (the hub) that all of the spokes attach to.
As a network topology, it means that you have a central switch/router (or core of switches/routers) that all of the peripheral / edge switches/routers connect to.
Versus something like TOken-RIng, where the physical topology was a hub & spoke (sometimes called a "star") but the electrical/logical path was a ring.
Or traditional Ethernet, where there was a single long segment of coax that each host connected to .... which is a "Bus" topology.
Good Luck
Scott
10xs
10xs for ur reply!
Ali
