HWIC-1FE in 2811 - still not seeing it
I upgraded the image to c2800nm-entservicesk9-mz.124-17.bin and reloaded it but it gives a new error message. This is the boot text I get:
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0003E7 0X003DA000 C2811 Mainboard
0X000021B8 Onboard USB
0X002C29F0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X008AFBA8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 10Mb.
Using 3 percent iomem. [10Mb/256Mb]
%GT96K_FEWAN-1-UNKNOWN_WIC: NM slot 0, wic card has an unknown id 53APort Statistics for unclassified packets is not turned on.
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
program load complete, entry point: 0x8000f000, size: 0x223b98c
Self decompressing the image : ######################################################################## [OK]
ID MEMORY_REQ TYPE
0003E7 0X00473800 C2811 Mainboard
TOTAL: 0X009493A8
Cisco IOS Software, 2800 Software (C2800NM-ENTSERVICESK9-M), Version 12.4(17), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 07-Sep-07 16:45 by prod_rel_team
Image text-base: 0x40094FC0, data-base: 0x427E8910
Cisco 2811 (revision 49.46) with 251904K/10240K bytes of memory.
Processor board ID FTX1125A62K
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Press RETURN to get started!
*Sep 12 14:37:11.051: %GT96K_FEWAN-1-UNKNOWN_WIC: NM slot 0, wic card has an unknown id 53A
*Sep 12 14:37:14.551: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Sep 12 14:37:14.555: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Sep 12 14:37:14.555: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
*Sep 12 14:37:15.911: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
*Sep 12 14:37:15.911: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Sep 12 14:37:16.347: %SYS-5-CONFIG_I: Configured from memory by console
*Sep 12 14:37:16.639: %SYS-5-RESTART: System restarted --
*Sep 12 14:37:16.643: %SNMP-5-COLDSTART: SNMP agent on host dod2811 is undergoing a cold start
*Sep 12 14:37:18.219: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
I dont see the card when I do show interfaces. At first before I upgraded the image I tried slot 0, then noticed that this was a voice only slot so I tried slot 1 and then slot 3 which it is in now.
Is there maybe a way to clear the slot configuration?
Any suggestions?
Re: HWIC-1FE in 2811 - still not seeing it
You should use 12.4 T-train.
12.4.15T for example
I will try now, whats the T train about?
For the HWIC-1FE and HWIC-2FE the minimum level is Cisco IOS 12.4(11) XJ.
Make sure your IOS version is higher than this for the modules to detect
http://www.cisco.com/en/US/products/ps5855/products_data_sheet0900aecd80581fe6.html
Narayan
604
