Webcast-Catalyst9k
HWIC-1FE on C2821 Router
I've intalled two HWIC-1FE on a C2821 router. All 3 LED lights are on each card. However, the IOS does not see them...
Could you please help?
Frank
2 ACCEPTED SOLUTIONS
Hall of Fame Super Blue
Re: HWIC-1FE on C2821 Router
Frank
Frank
Check the IOS version you are running with a "sh version". You need a minimum of 12.4(15)T - note it must be a T train release -
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80581fe6_ps5855_Products_Data_Sheet.html
Jon
Frank
As you sh version shows you need to upgrade your IOS to a minimum of 12.4(15)T.
Jon
Please post sh version and sh diag output of the router. Thanks
Ephraim,
Thanks for your prompt feedback.
I'm attaching the requested info...
Frank
Frank
Jon
Hi Jon,
Thanks for your help.
Doesn't my current IOS image support vlan config for HWIC-4ESW? The only option I get when entering the vlan command is accounting...
Frank
Frank
Have you seen my response in the other post ?
Jon
fntowo2009 wrote:
Hi Jon,
Frank
Frank
Quick follow up. In the other thread i said it was
router# vlan-database
it's actually
router# vlan database
told you my memory was a bit suspect
http://www.cisco.com/en/US/docs/ios/lanswitch/command/reference/lsw_u1.html#wp1012545
Jon
Frank
Frank
Jon
615
