04-23-2008 11:41 PM - edited 03-03-2019 09:40 PM
I have installed HWIC-1FE card on Cisco 2811 router but in show diag it shows "Unknown WAN daughter card
WIC module not supported/disabled in this slot ".
IOS Version which I am using is 12.4(17)bin with advance IP services K9 feature set.
can somebody help?
regds
aman
Solved! Go to Solution.
04-24-2008 02:18 AM
Yes or latest T.
04-23-2008 11:56 PM
You need 12.4(11)XJ4 or newer for that card.
04-24-2008 12:46 AM
But I have 12.4(17) working on router.
Is it like that I need 12.4(11)XJ only.?
aman
04-24-2008 02:18 AM
Yes or latest T.
04-29-2008 08:26 PM
I loaded 12.4(11)XJ image & card is working .
thanks.
aman
04-29-2008 10:28 PM
hi
what is the difference between T release or XJ image and images without either T or XJ etc
Tks
