HWIC-1T Loopback
Hi Chaps
Simple question (that I can't find the answer to anywhere)
On a HWIC-1T card what dows the loopback command actually do  ??
HWIC-1T Loopback
by configuring loopback in HWIC you can get  messages  which it is similar to an Internet Control Message Protocol (ICMP) ping message. Refer to the ping ethernet privileged EXEC command.
Hall of Fame Super Gold
HWIC-1T Loopback
That is wrong. Loopbak operation is very different from ICMP. Also "ping ethernet" as nothign to do with it.
To answer OP question, yes HWIC-1T supports looback just the same as other serial interfaces.
HWIC-1T Loopback
Hi Paolo,
the difference is in you manually apply ping to an IP address and you get reply, regarding this kind of loopback; you get a error messages when you faced some issue within the connection through the HWIC. this kind of messages appears like a debug output.  this informatioin I got form a trunbleshooting document I will send you a copy soon.
173
