Community Member
HWIC-2SHDSL
I have a 1841 with a 2SHDSL wic, testing using a BT SDSL circuit which works fine on a Cisco 878 router.
When I plug the same circuit into the SHDSL interface using the standard straight through cable which come with the 878 I am having issues with the DSL state transisioning from DSL UP to DSL DOWN and the light on L0 intermiently flashing. The atm pvc is established, but the virtual access interface has line up but line protocol down. The config of the controller is below I have a feeling the issue is with the cabling.
Has anyone come across this before or any suggestions would be welcome.
controller SHDSL 0/0/0
dsl-group 0 pair 0
shdsl annex B
shdsl rate auto
Hall of Fame Super Gold
Re: HWIC-2SHDSL
Likely it's not the cabling. You may need an IOS upgrade.
Community Member
Re: HWIC-2SHDSL
I am running advipservices 12.5(15)XY, which IOS version do you recommend
Re: HWIC-2SHDSL
One of the latest T for example.
Failing that post show controller atm x/y.
446
