The problem is I can't access the router from the internet. I am also an ocean away from the site. I have an ugly hack set up where I access an inside PC with Teamviewer and then puTTy to the router, but it is slow, ugly, and doesn't fix my problem. I need to be able to set up internet accessible servers at this location for VOIP, VPN, and REAL remote access.
Everything else works fine. Connection is stable. Speed is kinda shitty, but that's not so important.
First off some specs:
- Cisco 2801
- c2801-ipvoicek9-mz.124-24.T1.bin
- hwic-3g-cdma-s
- Sprint 3G data plan
Ok, I have set up the previous equipment as a router for a branch office where 3G access is the only available internet access.
I have had the excruciating experience of talking with Sprint Tech Support, and would rather shoot myself in the foot than do so again.
Here is what they told me: "They block ports, but they can't tell me which ones."
Here is relevant info I have been able to gather.
- The IP connection the ISP gives us is not NATTED. That is the address at wimi.com and show int dialer 0 is the same one.
- Most forums say Sprint only blocks port 80.
- Zenmap (nmap for windows) says the router has NO open ports but DOES exist.
- Router does not respond to pings
- Can't SSH into router from internet
- Can't access a test local server with port 8080 or 8081 open with the correct nat statement in Cisco router
- No filtering access-list for testing
The config should be just fine as a base config for using hwic-3g-cdma-s as the main internet access interface for a router. Everything works fine aside from the lack of remote access.
So in my head it has to be one of 3 problems.
1. The card is doing some weird stuff to incoming requests
2. Sprint is blocking WAN requests on port 22, 2200, 8080, and 8081 and pings (tested). Maybe they block all WAN requests?
3. There is something wrong with my config.
Any suggestions as to why I can't remote access into my router or things to try with the config?
Thank you in advance for your help
-Vittorio
Below are some config pastes:
chat-script cdma "" "ATDT#777" TIMEOUT 60 "CONNECT"
ip ssh authentication-retries 2
ip ssh port 2200 rotary 1
ip ssh version 2
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
ip address 192.168.30.1 255.255.255.0
ip nat inside
ip virtual-reassembly
speed auto
full-duplex
no cdp enable
no mop enabled
interface Cellular0/3/0
no ip address
ip nat outside
encapsulation ppp
dialer in-band
dialer pool-member 1
dialer-group 1
async mode interactive
interface Dialer0
ip ddns update hostname DYNDNSHOSTNAME
ip ddns update dyndns
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0 either
dialer string cdma
dialer persistent delay 5
dialer persistent max-attempts 5
dialer-group 1
no cdp enable
ppp chap password 7 WOOGYBOOGY
ppp ipcp dns request
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 192.168.30.103 8081 interface Dialer0 8081
access-list 1 permit any
dialer-list 1 protocol ip list 1
no cdp run
line 0/3/0
script dialer cdma
login local
rotary 1
no exec
transport input ssh
rxspeed 3100000
txspeed 1800000
line vty 0 4
password 7 02565D58030F01264340
logging synchronous
login local
rotary 1
transport input ssh
