HWIC-3G-GSM no traffic
I have configured cisco HWIC-3G-GSM router cellular and Dialer0 interfaces.
The WWAN LED is green solid (active, no traffic). I turned on debug chat, debug ppp negotiation, but no output generated.
I have also tried to ping to an internal network and a public ip, still no debug output.
cellular Profile status is inactive.
router#show cellular 0/0/0 security
Modem Security Information
Card Holder Verification (CHV1) = Enabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
Please advice.
Hall of Fame Super Silver
Re: HWIC-3G-GSM no traffic
Hello Leepeiwai,
you may need to create a modem profile before being able to use the HWIC. It is a sort or registration with mobile provider
see
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwlsgsm.html#wp1119164
Hope to help
Giuseppe
Yes, I have already created the profile at the beginning
#sho cellular 0/0/0 all
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = telstra.internet
Authentication = CHAP
Username: dummy, Password: dummy
Profile 4 = INACTIVE
PDP Type = IPv4
--More--                           Access Point Name (APN) = telstra.corp
Authentication = None
Username: , Password:
* - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
Inactivity Reason = Normal inactivate state
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
--More--                           Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
--More--                           Packet Service = UMTS/WCDMA (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = AUS, Network = Telstra
Mobile Country Code (MCC) = 505
Mobile Network Code (MNC) = 1
Location Area Code (LAC) = 12880
Routing Area Code (RAC) = 1
Cell ID = 708
Primary Scrambling Code = 459
PLMN Selection = Automatic
Registered PLMN =  , Abbreviated =
Service Provider = Telstra
Radio Information
Current Band = WCDMA 850, Channel Number = 4387
Current RSSI(RSCP) = -76 dBm
Band Selected = GSM EGSM/DCS
Number of nearby cells = 1
Cell 1
Primary Scrambling Code = 0x1CB
--More--                            RSCP = -78 dBm, ECIO = -9 dBm
Hello Leepeiwai,
this is fine
have you configured the chat script?
be aware that the string that follows the ATDT command is specific of the provider
Hope to help
Giuseppe
yes, chat script is applied. configuration as below:
chat-script NextG "" "ATDT*98*1#" TIMEOUT 60 "CONNECT"
interface Cellular0/0/0
no ip address
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer in-band
dialer pool-member 1
async mode interactive
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string NextG
dialer persistent
dialer-group 1
ppp authentication chap callin
ppp chap hostname dummy
ppp chap password 0 dummy
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
Hello Leepewai,
have you configured also the corresponding async line 0/0/0 ?
line 0/0/0
 exec-timeout 0 0
 script dialer NextG
 login
 modem InOut
see
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwlsgsm.html#wp1040391
Hope to help
Giuseppe
Yes I have, also read the doc link you provided
line 0/0/0
script dialer NextG
modem InOut
no exec
transport input all
I am able to connect and get an ip address from the Service Provider by changing the SIM card.
This time, unlike the previous SIM, the CHV1 code of this new SIM is disabled.
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
I this that is why I could not connect to the Service provider.
hey,
make sure of the below configurations:
1- chat script.
2- profile creation.
3- correct natting.
4- GSM or 3G coverage and configurations.
5- cellular interface ip address should be negotiated.
as well try to change the script to
chat-script NextG "" "ATDT*99*1#" TIMEOUT 60 "CONNECT"
i've never used a dialer config for GSM, i configure the cell interface directly as below:
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer string ISP
dialer-group 1
ppp chap hostname ISP
ppp chap password 7 ISP
1640
