Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
HWIC-4B-S/T
I have installed on HWIC-4B-S/T module in Cisco 3825 router,but the router is not detecting the module.....Please urgent help is required.....
regards,
Hall of Fame Super Silver
Re: HWIC-4B-S/T
Hello Venkataraman,
post a sh ver of your router
have you powered off the router before inserting the HWIC?
Hope to help
Giuseppe
Re: HWIC-4B-S/T
Hi Giuseppe,
Once I get the sh ver I will be forwarding it to you,meantime the IOS ver is 12.3,will it support?
regards,
Re: HWIC-4B-S/T
Hi Giuseppe,
Please see the below attached SH VER out put.
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.3(11)T8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 06-Oct-05 06:13 by kehsiao
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
BNC-Router-c3825 uptime is 3 hours, 1 minute
System restarted at 11:17:26 UTC Sun Oct 18 2009
System image file is "flash:c3825-spservicesk9-mz.123-11.T8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.0) with 227328K/34816K bytes of memory.
Processor board ID FCZ0943732L
2 Gigabit Ethernet interfaces
4 Serial interfaces
3 ISDN Basic Rate interfaces
1 ATM interface
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
The router is not accepting HWIC-4T module also.
Hall of Fame Super Gold
Re: HWIC-4B-S/T
You need to update your old IOS.
262
