HWIC-4SHDSL how many ports?
I was wondering how many ports this card has, I believe it is a single port, but I am a little bit confuse because in the overview of the cards says:
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7175/product_data_sheet0900aecd80581fa0.html
The 2-pair (HWIC-2SHDSL) and 4-pair (HWIC-4SHDSL) symmetric high-bit-rate DSL high-speed WAN interface cards (HWICs) provide G.SHDSL connectivity to a Wide Area Network (Figures 1 and 2). The 4-pair symmetric G.SHDSL HWIC provides two ports of 4-wire or four ports of 2-wire connectivity options, whereas the 2-pair G.SHDSL HWIC provides two ports of 2-wire or one port of 4-wire connectivity options. The 4-pair symmetric G.SHDSL HWIC also allows bonding single or dual-pair G.SHDSL ports up to a single 8-wire interface with increased bandwidth by using Inverse Multiplexing over ATM (IMA) or data interleaving with M-pair mode. These cards are supported in all integrated services routers that have HWIC slots.
any help is much appreciated.
1 ACCEPTED SOLUTION
Silver
Re: HWIC-4SHDSL how many ports?
That's correct!
Marco
Silver
Hi Juan,
HWIC-4SHDSL has a single port with RJ45 connector. The connector has 8 wires (4 pairs), and you can decide how to use those pairs.
For example, you can have a single interface, using 4 pairs, or you can have two different interfaces, each one with 2 pairs. These are IOS interfaces (in configuration), but the physical port is stil one.
Hope this clarifies.
Please rate the thread if useful
Marco
Hi Marco,
So they are reffering to logical ports when they say "two ports" or "four ports"?
Silver
That's correct!
Marco
Thanks Marco!
Very helpful your answer indeed.
Hall of Fame Super Gold
The explanation is very clear.
What is that you don't understand ?
333
