Webcast-Catalyst9k
HWIC - 4SHDSL
Dear Experts,
I want to replace the modem with the attached configuration (file attached: XAVI Modem Config.pdf) with the Cisco HWIC - 4SHDSL,
How can I do ?
Thanks in advance
1 REPLY
Hall of Fame Super Silver
Re: HWIC - 4SHDSL
Hello M.metwally,
you can follow the config guide for HWIC 4 GSHDL
http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/shdslfm.html
from your pdf:
mode : cpe means CO on other side
4 wire : important means usage of 2 pairsof wires
2-Pair groups—2 DSL pairs
From above link:
>> Cisco G.SHDSL HWICs support up to four pairs of digital subscriber lines (DSL): two inverse multiplexing over ATM (IMA) lines, and two ATM segmentation and reassembly (SAR) lines. The four DSL pairs are bundled in groups and configured in the Cisco IOS command-line interface (CLI) by using the dsl-group command.
G.SHDSL HWICs support the following DSL groups:
Inverse Multiplexing over ATM (IMA) groups—1- 4 DSL pairs
Multi-Pair Operation (M-Pair) groups—2 or more DSL pairs
1-Pair groups—1 DSL pair
pay attention to cables other users have had problem to figure the correct cabling.
Cisco HWIC-4SHDSL—Use a standard RJ-45 straight-through cable to establish connection between the HWIC and a network device.
http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/dsl_hwic.html#wp1068240
vpi/cpi : 8/35  ATM parameters for the ATM PVC to be used to talk with CO.
RFC 1483 bridged: means that ethernet frames are carried within ATM AAL5 PDUs
this requires use of RBE or IRB to be implemented
IRB means that the ATM interface has no ip address but it is given to the BVI interface, the L3 object of the bridge-group
bridge 1 protocol iee
bridge 1 route ip
int atm0
no ip address
bridge-group 1
pvc 8/35
enc aal5snap
int bvi1
desc L3 ip address here can be manually set of get from a DHCP server
ip address ...
Hope to help
Giuseppe
1022
