HWIC-4T1/E1 and VWIC2-2MFT-G703
Can anybody help me in clarifying what is the difference between
VWIC2-2MFT-G703 and 4 Port clear channel Module (HWIC-4T1/E1
)in Cisco Routers.
Please provide the suitable solution
I pretty sure VWIC2-2MFT-G703 can be configured for maximum of 2 Channel-groups. How about 4 Port Clear channel card? Whether i can configure 31 independant channels (31 Links)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: HWIC-4T1/E1 and VWIC2-2MFT-G703
According to the datasheet, either framed or unframed operation is supported:
The modules support balanced and unbalanced E1 connectivity and conform to G.703 and G.704 standards for unframed and framed E1 modes.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/product_data_sheet0900aecd80710c77.html
Have a look at the following link for the detailed feature information on the HWIC module -
http://www.cisco.com/en/US/docs/ios/12_4/12_4x/12_4_11xw/fmt1e1ic.pdf
Broadly speaking, HWIC does not supports Voice unlike the VWIC modules and HWIC (4 ports) supports 1 channel per port or 4 channels per module.
-> Sushil
Hi Sushil,
Thanks for your reply. I have surfed this link already before writing in this forum.
It is mentioned that 4 port clear channel supports only one channel.
1. is that mean i can configure only one channel group per port.
2. Whether it supports unframed also?
do you have any chance of worked with this port?
regards,
R.B.Kumar
Hi everybody,
Any clues..
VWIC2-2MFT-G703 and 4 Port clear channel Module (HWIC-4T1/E1 in Cisco Routers.
I am pretty sure VWIC2-2MFT-G703 can be configured for maximum of 2 Channel-groups. How about 4 Port Clear channel card? Whether i can configure 31 independant channels (31 Links)
No, sorry:
The 4-port clear channel HWIC supports 1 channel per port, or 4 channels total for the HWIC
From: http://www.cisco.com/en/US/docs/ios/12_4/12_4x/12_4_11xw/fmt1e1ic.html
Whether it is possible to create either framed (1984 Kbps-timeslot 1-31) or Unframed (2048 Kbps).
I know that it is not possible to create both in the same port. But I should be able to do it in atleast either
R.B.Kumar
1450
