HWIC_ADSL_BRI-7-NETSPURIOUSEVENT
I'm getting the following errors logged on one my 2811 routers with dual ADSL cards. The ATM0/1/0 status is also sat at initializing. Anyone any idea what the problem might be.
HWIC_ADSL_BRI-7-NETSPURIOUSEVENT: HWIC_ADSL_BRI 1: Spurious network interrupt 0 happened, mask 3FF
Hall of Fame Super Gold
Re: HWIC_ADSL_BRI-7-NETSPURIOUSEVENT
Typical bug symptom, try upgrading IOS but if it happens again you have to contact the TAC and ask to reproduce.
Hi! I also getting the similar error message as in below. I saw only one router. I don't see such errors in many other routers with the same IOS (c1900-universalk9-mz.SPA.152-1.T1).
If you have any update/ feedback, please help to share.
%HWIC_HDLC_BRI-7-NETSPURIOUSEVENT: HWIC_HDLC_BRI 1: Spurious network interrupt 0 happened, mask 700
Ye
It could be due to:
1. Card HW failure.
2. Loop length issue on the HWIC-1B-U cards:
CSCtl22335    %HWIC_HDLC_BRI-7-NETSPURIOUSEVENT: HWIC_HDLC_BRI 1:Spurious network
It was fixed with new HW revision of this cards).
3. pulsing signal on the link.
Kidn Regards,
Ivan Shirshin
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
Hi Ivan,
Thanks a lot for your prompt response. At present, the bug is under review and not shown.
Saved it to my watch list.
Ye
2278
