Webcast-Catalyst9k
HWIC BOND
Dear friends
I have two bar from 4 wire SHDSL HWIC card on my 3845 router. I have IAM on each HWIC to achive more bandwidth. I want to know is possible to bonding these two SHDSL HWic and use IAM on them to reach more bandwidth?
Hall of Fame Super Gold
Re: HWIC BOND
Hi, I think that with "IAM" you mean ATM IMA.
However, the shdsl hwic does not support ATM IMA.
Re: HWIC BOND
Acctully we can have IAM ATM on HWIC for SHDSL for bonding 4 pair or 4 line to about 10 Mbps..
Re: HWIC BOND
Hi, once again, that is spelled "ATM IMA (Inverse Multiplex Access)".
Now if you could provide a link that states that ATM IMA is supported on the the SHDSL HWIC, I will be glad to correct myslef in saying that it is not supported.
Re: HWIC BOND
Here is the link regarding IMA Hwic support :
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7175/product_data_sheet0900aecd80581fa0.html
"IMA (only on HWIC-4SHDSL)"
ATM Forum standard that provides a scalable and cost-effective way for service provider and end customers to expand WAN bandwidth by bonding one to four G.SHDSL links
Re: HWIC BOND
I think my answer above predates HWIC-4SHDSL, so I indicated no IMA support.
131
