Community Member
HWIC card for 1861
Can you tell me if the card HWIC-1SER is the equivalent card HWIC-1T for 1861 router?
HWIC card for 1861
The both will have different types of interfaces so they are not equalent.
HWIC-1SER -->1-Port Serial HWIC for 1861
HWIC-1T -->T1/E1 HWIC w/ Intg. CSU/DSU (1861-only)
Please rate the helpfull posts.
Naidu.
Community Member
HWIC card for 1861
I mean HWIC-1T=  and not HWIC-1T1/E1=
For example:
2901 with HWIC-1T is equivalent (about the compatibility card) to 1861 with HWIC-1SER ?
Community Member
HWIC card for 1861
HWIC-1SER= does not come with an integrated CSU/DSU and uses smart serial ports just as the HWIC-1T= does:
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/data_sheeet_serial_high_speed_waniInt_cards_for_1861.pdf
Regards.
285
