HWIC Card problem
Hi Everybody,
I am having problems with my 1841 recognizing the ADSL/SDSL HWIC cards. If I install a normal WIC card, then the problem disappears.
First I thought that the problem is the IOS version, but even after upgrading to a higher IOS version, I still have got the same problem.
Here is the show version output:
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(21), REL
EASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jul-08 00:16 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Satellite_office uptime is 19 minutes
System returned to ROM by reload at 13:10:16 UTC Tue Oct 7 2008
System image file is "flash:c1841-advsecurityk9-mz.124-21.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1841 (revision 7.0) with 233472K/28672K bytes of memory.
Processor board ID FCZ123211WC
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
show flash:
-#- --length-- -----date/time------ path
1 18716748 Aug 6 2008 00:35:30 +00:00 c1841-advsecurityk9-mz.124-3i.bin
2 2746 Aug 6 2008 00:51:14 +00:00 sdmconfig-18xx.cfg
3 931840 Aug 6 2008 00:51:36 +00:00 es.tar
4 1505280 Aug 6 2008 00:52:00 +00:00 common.tar
5 1038 Aug 6 2008 00:52:22 +00:00 home.shtml
6 112640 Aug 6 2008 00:52:40 +00:00 home.tar
7 527849 Aug 6 2008 00:53:00 +00:00 128MB.sdf
8 21270976 Oct 6 2008 16:26:38 +00:00 c1841-advsecurityk9-mz.124-21.bin
20926464 bytes available (43085824 bytes used)
I have run out of ideas, so I would be really grateful if someone could assist me with resolving this problem.
Should I have missed out any important details, please let me know.
Thanks for your help in advance,
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: HWIC Card problem
Actually the code that you are running is 12.4 main line code (c1841-advsecurityk9-mz.124-21.bin) and the recommended versions were in the T train or the XJ train (both trains are where newer technologies are introduced). So I suspect that you issue is indeed the version of code that you are running. I suggest that you try something recent in the 12.4T train and see if it does not resolve your issue.
Rick
Which HWIC card exactly (part number)?
Regards, Thomas
Part no:
HWIC-1ADSL
and
HWIC-2SHDSL
Thanks Thomas!
We have none of those in use currently, so I could not check. On CCO it says
- Minimum IOS Release 12.4(11)XJ
- Recommended IOS Release 12.4(6th)T
- Feature Set IP Base and up
Your IOS should be fine, but you may want to check with the recommended IOS (that is a long shot!).
Regards, Thomas
Thanks Thomas,
Appreciate your help! Can you think of anything other than the IOS that can cause this problem (supposing that the HWIC cards are working)
Cheers,
To be honest, not really. I would open a TAC case, there may be a bug for some releases.
Good luck ... Thomas
Rick
Thanks Rick!
As you suggested, the T train IOS did the job! :)
Thank you for posting back to the thread indicating that you had solved your problem. I am glad that my suggestion did point you in the right direction. Thank you for using the rating system to indicate that your problem was resolved (and thanks for the rating). It makes the forum more useful when people can read about a problem and can know that a response did lead to a successful solution.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
327
