HWIC not showing after upgrading IOS
Arshad Khan
HI,
I have Cisco 2801 router with IP Base image, i have upgraded its image into advance Ip services for using IP SLA features but after upgradation HWIC card not showing in configuration.
When i recall IP base image then configuration show presence of HWIC card but with advance IP services HWIC card not showing.
Kindly advice.
BR,
Arshad Ahmed
2 Accepted Solutions
Leo Laohoo
What is the HWIC card (exact part number)?
What is the exact IOS (post the "sh version" if you're not sure)?
Right-o.  You need a minimum of 12.4(20)T (IP Base feature set) to get to work.
1- and 2-Port Fast Ethernet High-Speed WIC for Cisco Integrated Services Routers
8 Replies 8
Jeff Van Houten
Level 5
Level 5
You need to research the hardware supported for the specific version of ios and the specific hardware you are using.
Talha Ansari
Hi Arshad,
Hope you have not downgraded the IOS version in the process of upgrading the featureset. Post here the current and previous image names.
Talha
Leo Laohoo
Dear All,
Kindly note down the IOS, ROUTER and HWIC details.
Router PID: CISCO2801 VO5
Previous IOS : c2801-ipbase-mz.124-15.T10
Current IOS :  c2801-advipservicesk9-mz.124-25a.bin
HWIC : HWIC-1FE
Arshad Ahmed
Hi Leo,
Thanks for reply.
As is need IP SLA feature so i have to implement c2801-advipservicesk9-mz.124-20.T.bin
but it require DRAM/FLASH 192/64 but memroy present in my Cisco 2801 is 128/64.
Arshad Ahmed
Arshad Ahmed
Clearly you have conflicting requirements. The features that you want require a version of code that requires physical resources greater than what your router has. There are only a couple of alternatives and you may not like any of the alternatives:
- you can upgrade RAM and flash.
- you can choose which of the features you can get along without (have the IP SLA without the WIC or have the WIC without the IP SLA).
Rick
Rick
Dear all,
Thanks for your helpfull reply.
I have order for DRAM and FLASH in this regards.
Arshad Ahmed
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
