I ask about Total output drops on the interface tunnel.
I then show interface tunnel effect that the "Total output drops" as many do not know what caused what. What should be changed. And you help me troubleshoot this issue sir.
please, find attach files for more detail.
::sample::
DC_RT#sh int tun 402
Tunnel402 is up, line protocol is up
  Hardware is Tunnel
  Description: ==ADC_WAN==
  Internet address is 172.29.103.13/30
  MTU 1514 bytes, BW 50000 Kbit/sec, DLY 500000 usec,
     reliability 255/255, txload 67/255, rxload 15/255
  Encapsulation TUNNEL, loopback not set
  Keepalive set (5 sec), retries 3
  Tunnel source 172.29.103.2, destination 172.29.103.1
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255
  Fast tunneling enabled
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 00:00:02, output 00:00:00, output hang never
  Last clearing of "show interface" counters 3d19h
  Input queue: 0/1000/0/0 (size/max/drops/flushes); Total output drops: 214560
  Queueing strategy: fifo
  Output queue: 0/1000 (size/max)
  5 minute input rate 3069000 bits/sec, 1463 packets/sec
  5 minute output rate 13234000 bits/sec, 2010 packets/sec
     124067359 packets input, 2539405689 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     162511528 packets output, 585971124 bytes, 0 underruns
     0 unknown protocol drops
DC_RT#
Thank you very much.
Everyone's tags (1)
Re: I ask about Total output drops on the interface tunnel.
I guess its a cisco 2821 router with hwic-4esw card. Are the output drops increasing continously? Try changing the load-interval to 30 seconds on the interface fas 0/0/0 and tunn 402 :
# int fas 0/0/0
# load-interval 30
# int unn 402
# load-interval 30
Monitor interfaces and see at what rate is the output drops increasing. What is the throughput of the link terminated on fas 0/0/0?
Dear Mr.Talha Ansari,
Thank you very much, I will try and I update let you know again.
Best Regards.
Mr. Amnaj Piyathamrat
Senior Network Engineer
MFEC Public Company Limited
Mobile: 085-151-1651
E-mail: amnaj@mfec.co.th
Dear Mr Talha Ansari,
Now I set "load-interval 30" on interface and tunnel. But it have "Total output drops" as well.
Best Regards.
Is the output drops increasing or is the value constant?
clear the counters and observe whether the o/p drop counter is increasing.
# clear counters
# sh int tunn 402
Dear Mr. Talha Ansari,
I clear counter on interface tun 402 about time 9.14 a.m. and now I show interface tunnel 402 again. Please you see this log at below. If you need to know more information, you can inform me.
Hardware is Tunnel
reliability 255/255, txload 51/255, rxload 10/255
Tunnel TTL 255
Last input 00:00:00, output 00:00:02, output hang never
Last clearing of "show interface" counters 06:40:47
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 65463
Output queue: 0/0 (size/max)
30 second input rate 2115000 bits/sec, 1447 packets/sec
30 second output rate 10061000 bits/sec, 1910 packets/sec
32348009 packets input, 3891025031 bytes, 0 no buffer
41882252 packets output, 3139881031 bytes, 0 underruns
DC_RT#
Best Regards.
988
