Webcast-Catalyst9k
I bought the wrong card for g703 unframed E1
Hi All,
i bought the wrong interface cards vwic3-1mft-e1/t1 and it is not working when my vendor trying to set it up.
Need some advise from you guys, if it is possible to configure the e1/t1 card to run on this g703 unframe link? understand the con will be 1984kbps instead of full 2048kbps.
Thanks in advance.
Hall of Fame Super Gold
Re: I bought the wrong card for g703 unframed E1
Yes it is possible, but the router on the other side must also be configured for 31 timeslots.
Hi Paolo,
so what i need to do are:
1) ask the local loop provider to change the 3 x NTU settings from unframed to Framed.
2) ask the PE router provider to configure their 3 x G703 cards to use timeslots as well.
doing the above at least can get my circuits up and running with 3 x 1984kbps combine. am i right?
1. Not needed. The circuit can remain unframed.
2. Yes.
Please remember to rate useful posts clicking on the stars below.
172
