Community Member
I Need a help for configuring the Backup Leased line
Hi All,
I Need a help for configuring the Backup Leased line .
This is my Network Stature  All our inside LAN  are statically routed our Cisco ASA from our ASA its routed to Our router.
Both in our ASA and router all the ports are already occupied. So how can i Configure the New Lease line from another vendor.
Roopesh
1 ACCEPTED SOLUTION
Hi Roopesh,
If you connected the new connection to your core switch...
You need to creat a vlan in your core switch in the subnet of your provider.
Then you can configure a sub-interface in your router for routing purpose.
And onemore thing is if you have a L3 switch as core, you can connect your new link and run routing in the core itself right as long as it have L3 features.
Please rate all the helpfull posts.
Naidu.
Hi Roopesh,
What you can do is, connect the new Leased line to any L2 switch and then connect that L2 switch to your network (it can be to your core switch).
Now you can do sub-interface in your router and configure accordingly as per your ISP.
This is the way you can achive it and the same what I have at one of my customer.
My customer have a 2801 router with just two Fastethernet ports those two ports using 1 for MPLS and another for P2P link. After some days my customer want to take another P2P link to another location So then I thought to do what I suggested above.
Naidu.
Community Member
Hi Naidu,
Thanku for the reply. I have red many articles of you in this forum.
But  we have only Layer 3 switch
i will explain
core switch 10.10.3.1 --> routed to ASA
ASA-->routed to Router
Roter having only two ports
one is conected to ASA
one is conected to ISP
If i Conect the new connection to Core switch .Can you explain briefly How it works.?
Roopesh
Hi Roopesh,
Naidu.
335
