i need a quick help plesae
i keep getting these messages:
00:18:38: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/1 Rx FIFO Overflow
00:18:43: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/0 Rx FIFO Overflow
00:18:49: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/0 Rx FIFO Overflow
00:18:55: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/0 Rx FIFO Overflow
on a 2600 switch.
Hall of Fame Super Gold
Re: i need a quick help plesae
IOS used ? Show interface for both FA, show what ?
Hall of Fame Super Blue
Looks like you might be hitting a bug. From Cisco release notes
CSCdy78397
Symptoms Performance may degrade and the following message may be generated for heavily utilized Fast Ethernet interfaces on a Cisco 2600 series router:
"%AMDP2_FE-3-RXOVERFLO: FastEthernet0/1 Rx FIFO Overflow".
During the time this message is displayed, performance may unexpectedly degrade even further.
Conditions This symptom is observed on a Cisco 2600 series router that is running Cisco IOS Release 12.2(11)T.
Workaround Reduce traffic on the interface until the message is no longer not displayed
Try upgrading your IOS
Jon
143
