01-15-2006 08:51 AM - edited 03-03-2019 11:27 AM
Dear sir,
i have configured cisco 2811 router in central site which have six wan interface. in central side i have three network.
1. 192.166.2.0/24
2. 192.168.1.0 /24
3. 192.168.10.0/24
my router fastethernet ip is 192.166.2.202 and i want to access my server from 192.166.2.0 network ip address of servers are 192.168.1.73 and 192.168.1.71 which i am not able to access . i have add the static route in routers also but i am not able access both the servers
Kindly suggest
ss yadav
01-15-2006 10:10 AM
The generic form for adding a static is:
ip route
or
ip route
If you do not specify the optional metric, the route using the gateway address will get a metric of one and the static using the "interface" keyword will get a metric of zero.
So, if I understand your setup, you'd use a command like:
ip route 192.168.1.0 255.255.255.0 192.166.2.202
or, if the 192.166.1.0 network was on you S0/0.100 subinterface it would look like:
ip route 192.168.1.0 255.255.255.0 interface S0/0.100
Again, the first example would get a default metric of 1, the second example would get a default metric of 0.
Be careful using static (and default) routes. It's easy to accidently se up a routing loop. If you start getting errors like "TTL Expired" .... you almost certainly have a routing loop.
If you need to remove the static route, just repeat the command (the whole command) with a "no" in front of it like this:
no ip route 192.168.1.0 255.255.255.0 192.166.2.202
Good Luck
Scott
01-15-2006 04:32 PM
Scott has done a good job of explaining the principles of configuring static routes. I offer one small correction: any static route gets an administrative distance of 1 (I know that there are multiple sources that say that there is an administrative distance difference between statics that specify a next hop address or statics that specify an output interface - but if you check the operation on the router all statics get an administrative distance of 1).
I am not clear about the original post, it describes having 6 WAN interfaces, then it talks about several networks and servers. Perhaps the original poster can be more specific about the topology and about what the problem is. If we understand better what is configured and what the problem is, then perhaps we can give better advice about what the solution might be.
Rick
