10-09-2006 03:27 AM - edited 03-03-2019 02:16 PM
hi...
the network design is...
r1(s0)-(s0)r2(s1)-(s1)r3(e0)-(e0)r4
r1)
interface Loopback0
ip address 7.7.1.1 255.255.255.0
interface Serial0
ip address 7.7.12.1 255.255.255.0
interface Serial1
no ip address
shutdown
router bgp 1
bgp router-id 7.7.1.1
bgp log-neighbor-changes
network 7.7.1.0 mask 255.255.255.0
neighbor 7.7.12.2 remote-as 234
r2)
interface Loopback0
ip address 7.7.2.2 255.255.255.0
interface Ethernet0
no ip address
shutdown
interface Serial0
ip address 7.7.12.2 255.255.255.0
clockrate 64000
interface Serial1
ip address 7.7.23.2 255.255.255.0
clockrate 64000
router eigrp 7
network 7.7.2.0 0.0.0.255
network 7.7.12.0 0.0.0.255
network 7.7.23.0 0.0.0.255
auto-summary
eigrp router-id 7.7.2.2
router bgp 234
bgp router-id 7.7.2.2
network 7.7.2.0 mask 255.255.255.0
neighbor 7.7.3.3 remote-as 234
neighbor 7.7.3.3 update-source Loopback0
neighbor 7.7.4.4 remote-as 234
neighbor 7.7.4.4 update-source Loopback0
neighbor 7.7.12.1 remote-as 1
r3)
interface Loopback0
ip address 7.7.3.3 255.255.255.0
interface Ethernet0
ip address 7.7.34.3 255.255.255.0
interface Serial0
no ip address
shutdown
interface Serial1
ip address 7.7.23.3 255.255.255.0
router eigrp 7
network 7.7.3.0 0.0.0.255
network 7.7.34.0 0.0.0.255
auto-summary
eigrp router-id 7.7.3.3
no eigrp log-neighbor-changes
router bgp 234
bgp router-id 7.7.3.3
network 7.7.3.0 mask 255.255.255.0
neighbor 7.7.2.2 remote-as 234
neighbor 7.7.2.2 update-source Loopback0
r4)
interface Loopback0
ip address 7.7.4.4 255.255.255.0
interface Ethernet0
ip address 7.7.34.4 255.255.255.0
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
router eigrp 7
network 7.7.4.0 0.0.0.255
auto-summary
eigrp router-id 7.7.4.4
router bgp 234
bgp router-id 7.7.4.4
network 7.7.4.0 mask 255.255.255.0
but r1's 7.7.7.0 subnetwork don't install r3,r4's routing table.
so not ping from r4 to r1's 7.7.7.0!
why??!!!! please ㅜㅜ
Solved! Go to Solution.
10-09-2006 03:54 AM
You are running iBGP so in order to install another iBGPs network, you need to enter the following command under the BGP process
no synchronization
or, you need to employ an IGP (static or dynamic routing) to install those routes.
To learn about synchronization, please read
http://www.cisco.com/warp/public/459/bgp_noad.html
__________
Please rate helpful posts.
10-09-2006 03:54 AM
no synchronization
__________
10-09-2006 04:10 AM
I assume you mean 7.7.1.0 and not 7.7.7.0 since I cannot see 7.7.7.0 even in router 1.
All IBGP routers need to be connected to all other IBGP routers within a AS to function properly. BGP will not advertise a route learned via IBGP to another IBGP neighbor.
You will need to put in route reflectors to make this work.
10-09-2006 04:05 AM
Hi ,
Due to split horizon also , a neighbor will not reflect updates to next neighbor until its disabled. .. so u need to have route-reflector also installed and no synchronization .. see if this works
it would be helpful if u can send routing table / database entries..
10-09-2006 04:32 AM
Split hotizon would only be a issue with EIGRP. BGP does not worry about split horizon because it uses a session based communication where EIGRP is using multicast. Even then there are no point to multipoint conenction so even EIGRP will not have a issue. If he is running a newer IOS level synchronization is disabled by default.
10-09-2006 08:15 AM
hey man..if u see the answer below also..he talks about the route reflector ...somewhere i read its like a split horizon ..where in the router reflecter clients are not given routes via central router...so it has to be configured as router reflector server...then routes are advertised from one neighbor to another..esp. in hub spoke locations
10-09-2006 04:40 AM
BGP does not advertise the networks if the entry is not found in its internal IGP routing table. This default behaviour can be overidden by the command "no synchronization"
ALso one IBGP peer does not advertise the routes to another IBGP peer to avoid loops.
For this you have to either configure route reflectors or you should have full mesh between all of your IBGP peers.
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ics/icsbgp4.htm
Narayan
