iBgp full mess
Can anybody tell me the equation you use to calculate how many ibgp sessions you need to create a full mess ( with x amount of bgp peers)
Thanks for your help!
1 ACCEPTED SOLUTION
Re: iBgp full mess
n*(n-1)/2
where n is the number of nodes running BGP
Since this would sometimes result in a large number of IBGP sessions you can implement RR(route reflectors) and confederations.
Narayan
Re: iBgp full mess
n*(n-1)/2
Narayan
Re: iBgp full mess
That's it...couldn't find it, thanks
Re: iBgp full mess
if you have X amount of BGP Peers then you will have X(X-1)/2 session in your AS
regards
Devang
Re: iBgp full mess
The [n(n-1)]/2 is a good general calculation for full mesh. Used to be used a lot before in Frame-Relay when calculating the number of PVC's needed for full mesh.
Just my additional $.02.
-lloyd
156
