Webcast-Catalyst9k
ibgp-->ebgp
Experts need your assistance
R12----iBGP--->R5---eBGP----->R4-----eBGP------->R2
i have one router advertised in iBGP R12, that route is injecting into ebgp router R2, please help me to understand why this route injecting into R2. details are below..!!
R12
router ospf 1
log-adjacency-changes
network 12.12.12.12 0.0.0.0 area 0
router bgp 65000
no synchronization
bgp log-neighbor-changes
bgp suppress-inactive
network 12.12.12.12 mask 255.255.255.255
neighbor 5.5.5.5 remote-as 65000
neighbor 5.5.5.5 update-source Loopback1
neighbor 5.5.5.5 next-hop-self
no auto-summary
R5#
router bgp 65000
no synchronization
neighbor 12.12.12.12 remote-as 65000
neighbor 12.12.12.12 update-source Loopback1
neighbor 12.12.12.12 next-hop-self
neighbor 192.168.1.4 remote-as 65100
no auto-summary
R4
router bgp 65100
no synchronization
neighbor 192.168.1.5 remote-as 65000
neighbor 200.200.1.2 remote-as 65200
no auto-summary
R2#
BGP table version is 6, local router ID is 200.200.1.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 12.12.12.12/32   200.200.1.4                            0 65100 65000 i
*> 160.160.1.0/24   200.200.1.4              0             0 65100 i
*> 160.160.2.0/24   200.200.1.4              0             0 65100 i
R2#
thanks in advance..!!
Re: ibgp-->ebgp
eBGP connections don't use the same rules as ibgp. When using ibgp, the ibgp neighbor cannot advertise an ibgp learned route to another ibgp neighbor. This is why it requires a full mesh or route reflectors in order to workaround those rules. Your diagram, however, is an ibgp neighbor advertising to another ibgp neighbor, which then CAN advertise to an ebgp neighbor. You can avoid this if you want by setting the community local-as or no-export, or configuring an outbound route-map on R5 that matches the route and denies it from being advertised to your ebgp peer.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Re: ibgp-->ebgp
Can u plz share configuration of R2....
ibgp-->ebgp
Appreciate for your response, here is the R2 config. thanks
R2#sh run | se router
router bgp 65200
no synchronization
neighbor 200.200.1.1 remote-as 65000
neighbor 200.200.1.1 next-hop-self
neighbor 200.200.1.4 remote-as 65100
no auto-summary
R2#sh ip rou 12.12.12.12
Routing entry for 12.12.12.12/32
  Known via "bgp 65200", distance 20, metric 0
  Tag 65100, type external
  Last update from 200.200.1.4 00:00:21 ago
  Routing Descriptor Blocks:
  * 200.200.1.4, from 200.200.1.4, 00:00:21 ago
      Route metric is 0, traffic share count is 1
      AS Hops 2
      Route tag 65100
R2#
Purple
ibgp-->ebgp
As John already explained this is normal behaviour and you'll have to filter this route on R5 if you don't want it to go to R2( using a route-map or a prefix-list or distribute-list outbound) or you can use community(setting it to local AS or no-export) when advertsing it to R5 with the network command using a route-map and sending the community to R5.
Alain
ibgp-->ebgp
Thanks john for clearifiying me,
it means eBGP doesn't care, it'll take any route from anyone unless we specifically configured to ignore routes.. Thats why i am seeing routes in R2 which is advertised in R12 iBGP. please let me know if my understanding is correct.
Thanks in advance.
Purple
ibgp-->ebgp
BGP will  advertise best routes and eBGP peer will accept it as long as it doesn't see its own AS in the AS_PATH.
Alain
228
