ibgp issue
Hi all,
Without using route reflector and conferdaration, if 5 router connected via ibgp, does each router has 4 neighbors?
Re: ibgp issue
That is correct. To get a full mesh you'd need 4 neighbors on each router.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Re: ibgp issue
hi.
in fully mesh,every router will have 4 neighbours.
Saran Bhatia
CCNP
Re: ibgp issue
In addition to other posts i would like to reinstate that you can create a peer group if you have same admin policies applicable to all the 4 neighbors by doing so you can reduce the excessive usage of memory and also defining / configuring policies for each peer ..
regds
104
