iBGP neighborship issue
Hello friends,
Need your help,
I have 6 routers configured with BGP, r1 directly connected to r2 and r3, r4 is directly connected to r2 and r3, and all are running iBGP AS 100,
where as r5 is directly connected to r3 and running eBGP(AS 200) and r6 is directly connected to r4 and running eBGP(AS 300) as well.
THE PROBLEM THAT I AM FACING IS WHEN R1 ESTABLISHES iBGP NEIGHBORSHIP WITH R4 WHICH ARE NOT DIRECTLY CONNECTED AND EVERY FEW SECONDS THE HOLD TME EXPIRES NEIGHBORSHIP IS BROUGHT DOWN, AND AGAIN IT COMES UP AND IT CONTUNES FOR EVER.
Please explain this behavoir and what extra configuration to be done to keep the iBGP neighborship between r1 and r4 permanant up.
find the attached config files and topology for ref.
  • WAN Routing and Switching
Everyone's tags (1)
1 ACCEPTED SOLUTION
Purple
yes you're right you'll have to use static route.
don't forget that by default eBGP has a TTL of 1 so you'll have to use the neighbor x.x.x.x ebgp-multihop command if you're peering on the loopacks.
Regards.
Alain.
Hall of Fame Super Silver
Hello Syed,
an IGP protocol or static routes are needed in order to be able to setup iBGP sessions between non adjacent routers.
try by adding on each router
router ospf 100
network 192.168.0.0 0.0.255.255 area 0
on all routers
this will provide the necessary IP connectivity to build the sessions
be also aware that best practice for iBGP is the use of loopback address as source and destination of the iBGP sessions
Hope to help
Giuseppe
hi Giuseppe Larosa,
Thanks a lot for replying.
I was thinking when r1 knows routes to r2 and r2 knows routes to r4, and since bgp is established between them, then why the holddown timer is expiring every now and then.
so this BGP's property, if it is not learning about this network from an igp o static it will not send it to its peers. am i right.??
Re: iBGP neighborship issue
Hello Syed,
the problem is that you would like to use iBGP sessions to also provide information about the iBGP destination addresses.
This is probably causing a consistency failure:
when iBGP session between R1-r4 is down R1 and R4 know about the iBGP endpoint of their session from the session they have with R2. So the session R1-R4 can come up.
As soon as the session between R1,R4 comes up R1 can see R4 IP address via the SAME iBGP session and this is not considered valid ( consistency check) and the session falls down.
And the cycle repeats for ever.
These are the kind of problems you face without an IGP or static routes in place :
Think of BGP sessions between not adjacent routers as user traffic as a telnet session or an ftp session: routing has to be stable and learned by an indipendent source ( static routes or IGP) in order to achieve stable sessions.
You could fix using network commands instead of redistribute connected and avoiding to have R4 to advertise R4-R2 IP subnet and R1 to advertise R1-R2 Ip subnet. However, this would not be real world just an exercise and there are only 4-6 routers involved what for an ISP with hundreds of routers?
Edit:
you have even two iBGP sessions with R4
from R4 cfg:
interface GigabitEthernet1/0
>>>>ip address 192.168.1.14 255.255.255.252
negotiation auto
interface GigabitEthernet2/0
ip address 10.1.1.1 255.255.255.252
negotiation auto
interface GigabitEthernet3/0
>>>>ip address 192.168.1.10 255.255.255.252
negotiation auto
and on R1 configuration:
outer bgp 100
no synchronization
bgp log-neighbor-changes
network 192.168.1.1
network 192.168.1.5
neighbor 192.168.1.2 remote-as 100
neighbor 192.168.1.6 remote-as 100
>>>> neighbor 192.168.1.10 remote-as 100
>>>> neighbor 192.168.1.14 remote-as 100
no auto-summary
This is not the way to use iBGP.
Use loopbacks and an  IGP and you will see  a stable network scenario
you need neigh x.x.x.x update-source loop0 to use loop0 as source
only one session between each pair of nodes and so on
Hope to help
Giuseppe
Hi Giuseppe,
I changed the config as adviced, i used loopbacks and an IGP(OSPF) and only one session per each pair of nodes.
lo0 as update source.
But after that all BGP neighborships went down and are in active state, can u help me here.
Purple
can you post your new configs.
Regards.
Alain
hi cadet,
Below are the configs, please help me with this issue.
configs for R1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex half
ip address 192.168.1.5 255.255.255.252
negotiation auto
ip address 192.168.1.1 255.255.255.252
negotiation auto
no ip address
shutdown
negotiation auto
router ospf 1
log-adjacency-changes
router bgp 100
no synchronization
network 192.168.1.1
network 192.168.1.5
neighbor 192.168.1.2 update-source Loopback0
neighbor 192.168.1.6 update-source Loopback0
no auto-summary
For R2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
no ip address
shutdown
duplex half
ip address 192.168.1.13 255.255.255.252
negotiation auto
ip address 192.168.1.2 255.255.255.252
negotiation auto
no ip address
shutdown
negotiation auto
router ospf 1
router bgp 100
no synchronization
network 192.168.1.2
network 192.168.1.13
neighbor 192.168.1.1 remote-as 100
neighbor 192.168.1.1 update-source Loopback0
neighbor 192.168.1.14 update-source Loopback0
no auto-summary
For R3
interface Loopback0
ip address 3.3.3.3 255.255.255.255
no ip address
shutdown
duplex half
ip address 192.168.1.6 255.255.255.252
negotiation auto
ip address 20.1.1.1 255.255.255.252
negotiation auto
ip address 192.168.1.9 255.255.255.252
negotiation auto
interface GigabitEthernet4/0
no ip address
shutdown
negotiation auto
router ospf 1
router bgp 100
no synchronization
network 20.1.1.1
network 192.168.1.6
network 192.168.1.9
neighbor 20.1.1.2 remote-as 200
neighbor 20.1.1.2 update-source Loopback0
neighbor 192.168.1.5 remote-as 100
neighbor 192.168.1.5 update-source Loopback0
neighbor 192.168.1.10 update-source Loopback0
no auto-summary
For R4
interface Loopback0
ip address 4.4.4.4 255.255.255.255
no ip address
shutdown
duplex half
negotiation auto
negotiation auto
negotiation auto
no ip address
shutdown
negotiation auto
router ospf 1
router bgp 100
no synchronization
network 10.1.1.1
network 192.168.1.14
network 192.168.1.19
neighbor 10.1.1.2 remote-as 300
neighbor 10.1.1.2 update-source Loopback0
neighbor 192.168.1.9 remote-as 100
neighbor 192.168.1.9 update-source Loopback0
neighbor 192.168.1.13 remote-as 100
neighbor 192.168.1.13 update-source Loopback0
no auto-summary
Purple
1) your loopack interfaces must be reachable via OSPF if you want to use them for peering:
    eg on r1:
router ospf 1
network 1.1.1.1 0.0.0.0 area 0
same thing on other AS 100 routers
2) peering with r2:
  neighbor 2.2.2.2 remote-as 100
same thing for other iBGP peers
Regards.
Alain
Hi cadet,
Thank you for your help, successfully created iBGP full mesh.
For eBGP from R3 to R5, when i mention loopback as update source and not running any IGP, i will not have reachability for loopbacks eitherways so i think i should use static routes or is there any other alternative for this.
Please advice.
Purple
Regards.
Alain.
858
