09-07-2006 03:46 PM - edited 03-03-2019 01:54 PM
I ran across a document named "BGP Case Studies" earlier this week:
http://www.cisco.com/warp/public/459/bgp-toc.html
It has a line that says:
"The set clause for outbound route maps does not affect routes that reflect to iBGP peers"
This means just reflected routes (client -> route reflector -> other client), right? I think the RR should still be able to set properties on his own updates sent to RR clients.
Anyone know this for certain? I don't have a lab setup to test this....
Thanks!
-Mason
09-07-2006 04:52 PM
According to this article and section. Yes, because you only apply the route-map to the RR client. Only if you also apply the route-map to the iBGP peer, then it will also affect the routes to iBGP peer.
Hope this helps.
09-08-2006 03:05 AM
Changing attributes on updates received from eBGP peers is not an issue and should work just fine even on the RR.
A route-map will allow you to change certain attributes even on reflected routes. Routing loops can be introduced if not used carefully.
Hope this helps,
