icmp error on PAT
I'm seldomly having problems with pat. Some times one of our PCs on the LAN can access the Internet.
If we execute a 'show ip nat translations' command, the ip with the nat problems appears with a icmp error.
The problem is solved imediately performing a 'clear ip nat trans...'
Is this a bug?
The version we're using is:
(C2801-SPSERVICESK9-M), Version 12.4(1a), RELEASE SOFTWARE (fc2)
And this is the nat part of the config:
ip nat inside source list 101 interface ATM0/3/0.2 overload
Thanks and best regards.
Enric
151
