Identifying Cisco IOS
Can anybody please tell me how to identify Cisco IOS given the part code??
I want to upgrade the IOS on my Cisco 3745 router and if i got the part number as "S374AESK9-12307T", which IOS version it corresponds to?? Is it 12.4 or 12.3??? Also, can anybody guide me for the above mentioned IOS part code whether the IOS file name is "c3745-adventerprisek9-mz " only??
Please guide me??
1 ACCEPTED SOLUTION
Re: Identifying Cisco IOS
Hi Parag,
The part number which you have given only corresponds to 12.3 and the file name what you mentioned is correct c3745-adventerprisek9-mz.
The part number corresponds to
Image Name Release Platform Feature Set
c3745-adventerprisek9-mz.12.3-7.T 12.3(7)T 3745 ADVANCED ENTERPRISE SERVICES
c3745-adventerprisek9-mz.12.3-7.T1 12.3(7)T1 3745 ADVANCED ENTERPRISE SERVICES
c3745-adventerprisek9-mz.12.3-7.T10 12.3(7)T10 3745 ADVANCED ENTERPRISE SERVICES
c3745-adventerprisek9-mz.12.3-7.T11 12.3(7)T11 3745 ADVANCED ENTERPRISE SERVICES
c3745-adventerprisek9-mz.12.3-7.T12 12.3(7)T12 3745 ADVANCED ENTERPRISE SERVICES
c3745-adventerprisek9-mz.12.3-7.T2 12.3(7)T2 3745 ADVANCED ENTERPRISE SERVICES
c3745-adventerprisek9-mz.12.3-7.T3 12.3(7)T3 3745 ADVANCED ENTERPRISE SERVICES
c3745-adventerprisek9-mz.12.3-7.T4 12.3(7)T4 3745 ADVANCED ENTERPRISE SERVICES
c3745-adventerprisek9-mz.12.3-7.T7 12.3(7)T7 3745 ADVANCED ENTERPRISE SERVICES
c3745-adventerprisek9-mz.12.3-7.T8 12.3(7)T8 3745 ADVANCED ENTERPRISE SERVICES
c3745-adventerprisek9-mz.12.3-7.T9 12.3(7)T9 3745 ADVANCED ENTERPRISE SERVICES
You can open the link for feature navigator
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
then click on
Search by Software/Image Name/Product Code/Platform
Then enter the part number under
Product Number
and you will get these details.
HTH, if yes please rate the post.
Ankur
Hi Parag,
then click on
Product Number
Ankur
Do find the IOS codes which is being suggested to get migrated to the new Advanced Enterprise Services C3745-adventerprisek9-mz
ENTERPRISE FW IDS PLUS IPSEC 56
C3745-jk8o3s-mz
ENTERPRISE FW IDS PLUS IPSEC 3DES
C3745-jk9o3s-mz
ENTERPRISE PLUS IPSEC 56
C3745-jk8s-mz
ENTERPRISE PLUS IPSEC 3DES
C3745-jk9s-mz
IP FW IDS PLUS IPSEC 56
c3745-ik8o3s-mz
IP FW IDS PLUS IPSEC 3DES
c3745-ik9o3s-mz
IP PLUS IPSEC 56
c3745-ik8s-mz
IP PLUS IPSEC 3DES
c3745-ik9s-mz
IP IPX APPLETALK PLUS FW IDS
I think you can check off with the current ios file name and find out whther you are trying out for a possible best feature set.
for more info you can refer this link up..
http://www.cisco.com/en/US/products/sw/iosswrel/ps5460/prod_bulletin09186a00801af451.html
regds
296
