Community Member
If a cisco router can work as ES in ISO IS-IS topo?
we want to use this router as ES only, then connect to another router work as a IS. and use ES-IS between them.
1 REPLY
Hall of Fame Super Silver
Re: If a cisco router can work as ES in ISO IS-IS topo?
Hello Xu,
refer to the doc
http://www.cisco.com/en/US/docs/ios/isoclns/configuration/guide/configure_iso_clns_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1070449
a cisco router can interact with ES but probably can only an IS
So you should build an IS-IS adjacency instead.
You can make the cisco router a L1 only and the other router L2/L1 to be its exit point.
Hope to help
Giuseppe
105
