If redistribution of IS is not specified, should I do level-1-2 ?
Hi, can you confirm this:
Imagine I am asked to perform redistribution from ISIS into EIGRP.
If the ISIS level is not specified in the exercise, do you agree it is the correct approach if I do level-1-2 to cover all scenarios ? For example:
#redistribute isis level-1-2 metric 500 1 255 255 1500
1 ACCEPTED SOLUTION
Re: If redistribution of IS is not specified, should I do level-
I agree that this would cover all ISIS routes that might be present in the local router RIB. If this doesn't go against against the specification then you should be in business.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
1 REPLY
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
97
