04-20-2006 07:02 PM - edited 03-03-2019 12:27 PM
if this two module 7300-4OC3POS-SMI and
PA-POS-OC3SML can connecter directly,
just like 5486 connect 5487.
thank you very much
04-20-2006 07:06 PM
You should be able to link these two together. However, you will have to use an appropriate optical attenuator because the transmit level from the SML port will be much higher than the receiver on the SMI can handle.
Pls do remember to rate posts.
Paresh
04-20-2006 09:15 PM
thank you.
cause i am from asia. so what mean of rate posts.
04-20-2006 09:30 PM
Do you see an option on the right with RATE THIS POST?
Check it, you'll see that you can rate or give points to the solutions provided.
Vlad
04-20-2006 10:06 PM
then what will happen if there is no optical attenuator ,the module's port will be damaged or they
can't communicate.
RATE THIS POST is which module options,if it is on the module 's faceplate.
warm regards
04-21-2006 02:14 PM
Yes, you are likely to damage the port if you don't use an attenuator.
Regarding "RATE THIS POST" - when you ask a question in thie forum and someone responds to it, you can give some points to the person to indicate that the reply was helpful to you. If you look at the bottom right of the message, you will say something called 'Rate this post'. If you click on it, you can then assign some points to the message.
Paresh
