Webcast-Catalyst9k
IKE tunnel between 7600 and 7200
    i have two routers C7606 and C7200 connected through WAN connection.
i configured tunnel between these two sites with route-map to match and take action for the specified traffic.
although the traffic match the access-list , but the action not taken .
also,the tunnel is up up
Hall of Fame Super Silver
Re: IKE tunnel between 7600 and 7200
Hello Ibrahim,
you need to apply the PBR route-map where traffic is received (PBR acts on inbound packets).
Example:
int vlan 20
desc internal lan
ip policy route-map Replication
Hope to help
Giuseppe
i am putting this command under the physical interafce as it the incoming interface .
also i see ACL match but dosn't take the decision.
Hello Ibrahim,
sorry for the basic question I did but sometimes this aspect is misunderstood
you could use
debug ip policy
for further troubleshooting it can provide info about why traffic is not policy routed.
it looks like that PBR is bypassed.
What side are you looking at ? the C7200 or the C7600 becuase these two devices have different architectures.
Another point: have you configured any static route using the tunnel interface ( a floating static route )
example
ip route 172.29.2.0 0.0.0.255 tunnel1 250
Hope to help
Giuseppe
Hello Giuseppe,
      i looking from C7600 side.
i didn't configured route, but through my troubleshooting i tried to make a route based on the tunnel.
124
