Webcast-Catalyst9k
Incomplete ARP Entries
I have a WS-C6506-E switch. There is an IP connected to a particular VLAN. Iam getting Incomplete ARP entries for that IP. How do i find out to which port is it connected?
Re: Incomplete ARP Entries
Can we check which port the device is attached to if there is no ARP entry for that IP? Awaiting reply.
Thanx in advance.
Hi Navneet
You can use the command
show mac-address-table vlan
This will show u the port from where it is elarning the MAC .
You can also use other swtiches for this command.
Check if this helps.
137
